It is currently Fri 11. Apr 2025 13:42:09
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Sun 31. Jan 2016 22:03:23
mohu, ale tak ci tak ho nedoporucuji pouzit. Jakykoli profil z jine heli by se mel pouzit spise jen k nahlednuti. Pokud je heli osazena stejne a je uplne stejne mechanicky nastavena, pak se da pouzit. I tak vice nez 3 hodnoty parametru nema cenu "okopirovat", ostatni uz jsou veci, ktere ma kazdy trochu jinak.
Jakmile je ale nekde jine servo, muze byt nastaveni uplne jine a poleti to spatne.
Spise je lepsi napsat, co zlobi a poslat tve nastaveni.
U Protose to byva vetsinou vrtulka. Nejcasteji je problem v mechanice - nejde tak jak by mela (i kdyz je heli treba uplne nova). S protosem mam hodne zkusenosti, takze mohu pomoci.
PostPosted: Mon 01. Feb 2016 22:13:48
Díky za odpověď, přiložil jsem své profily http://www.spirit-system.com/phpBB3/viewtopic.php?f=17&t=102&p=13371#p13371
Koukni prosím na to.
Díky
Protos,Agile 5.5,T14SG.....
PostPosted: Tue 09. May 2017 20:25:36
reports unsupported for version 2.4
PostPosted: Mon 10. Aug 2020 12:21:38
I am using a Spirit Pro with Geolink and an SRXL2 4651T receiver.When uploading the 4ds file on the profile viewer beta webpage, I get belo error:
Code:
index receiver_values and value 6 not found
Is SRXL2 not yet supported?
PostPosted: Sat 15. Aug 2020 18:11:33
Is there a problem with reading the file when using a SRXL2 type receiver? Where do I have to report a possible bug?
Thanks!
PostPosted: Sat 15. Aug 2020 22:50:27
we will try to sort it during next week. Thank you for your patience. Unfortunately we are still extremely busy.
PostPosted: Sun 16. Aug 2020 7:39:38
No problem!
Thank you very much for all the great work!
PostPosted: Wed 23. Jun 2021 17:09:44
unfortunately, this no longer works with the current version.
The following message appears:
Unsupported version: heli-3.2.1
I would be happy if you would update the tool!
Thank you very much
Micha
PostPosted: Tue 25. Jan 2022 18:40:00
Error still shows, any chance you can fix this?
PostPosted: Thu 17. Feb 2022 20:48:45
we will make completely new viewer. It will work with all versions without error.
