It is currently Tue 04. Jun 2024 2:00:38
heliflieger8587
Posted: Sun 13. Sep 2020 14:33:54 |
Here my settings for the Goblin 700.
Posted: Sun 13. Sep 2020 17:24:58 |
Thank you very much for the video.
If time will allow tomorrow we can prepare special firmware for you. It will be interesting to see if it will help. So we can make it perfect for F3C. Then it can be embedded in official firmware later.
eric38
Posted: Mon 14. Sep 2020 9:07:13 |
Hello, I'm new Spirit RS user, i tried and settings yesterday afternoon on my Urukay, i remembered your problem and i tried but no problem, the model stay strictkly vertically without correction. Eric
heliflieger8587
Posted: Mon 14. Sep 2020 9:30:41 |
Hello Eric,
it depends on how hard you fly the curve. If you make a big bow, the problem does not occur, or only minimally. If you fly quickly with a small radius, this effect occurs.
When the candle goes out this is e.g. not disturbing, because you have to take your nose down anyway to pick up speed again.
greetings Björn
fri09
Posted: Wed 16. Sep 2020 18:52:04 |
I definitely don't want to stress! I'm just curious if you will provide the special firmware before weekend? The weather will be great and it would be a great chance to test it...
Frieder
Posted: Thu 17. Sep 2020 7:46:20 |
heliflieger8587
Posted: Fri 18. Sep 2020 10:41:18 |
I am currently on the flight field and test your new version. I must unfortunately say, that the effekt is also present with this version. I think not so hard, but with a higher rpm my goblin flip about 15°
Have you any ideas, what we can do next?
Bjoern
tomsl
Posted: Sat 19. Sep 2020 2:43:05 |
Joined: Tue 10. Sep 2019 3:02:10 Posts: 33 Location: Whitehall Michigan USA
Hello I can confirm this problem I was flying today and I have the same behavior 15°
Thomas
_________________ official hacker distributor USA www.hackermotors.us
fri09
Posted: Sat 19. Sep 2020 8:20:39 |
here is what I experienced with the special firmware: The first candle I flew had the same effect like before. The following candles the tilt became less until it was nearly gone. But the firmware also caused other unwanted behavior. First of all it feels less stable while cruising and in straight passages. When I steer pitch while flying forwards the heli does an additional nick-movement, so that it flies in shape of a wave.
Beside the "candle-problem", I also still have a bouncing after cyclic input, regardless of the new firmware. Setting the Elevator Filter to 4 helped a lot. So I wonder if it would be possible to increase that damping-effect (like a value of 5)?
Great thanks for your effort!
Frieder
Posted: Sat 19. Sep 2020 10:06:18 |
in that case the problem seem to be something else.
Can you verify what will be result when Flight Style is set to 1?
