It is currently Fri 22. Nov 2024 19:36:53
PostPosted: Sat 06. Jun 2015 21:27:45
Hi, first-time setting up the unit. Need help with the tail movement please ?
The servo acts correctly against the transmitter input - moves in the opposite direction. However, when the heli is powered and I rotate the heli horizontally, the servo follows the movement, instead of counteracting it.
I cannot find a parameter to reverse the tail / rudder ? something, or somewhere else that needs to be set and corrected ?
PostPosted: Sat 06. Jun 2015 21:32:03
this parameter is in setup Wizard in our software and also in the Sensor tab, Z - Yaw.
PostPosted: Sat 06. Jun 2015 22:47:18
Thanks ! !!!!
Fixed Maiden for the unit in the morning ,
PostPosted: Sat 06. Jun 2015 22:52:19
You are welcome.
Make sure that Piro Optimization parameter is configured after configuring Sensor compensation direction.
PostPosted: Sun 07. Jun 2015 17:29:32
Hi, the heli and my nerves survived the maiden session !!! ;)
You were right : the piro needed to be reversed. whether it was wrong before doesn't matter, your comment made me look and all is well in this regard.
I'm using throttle curves at the moment and no stabi. I spend time to find the gyro settings. Very windy for the little 450x.
I have one problem that I need some help and directions on please ?
Tail holds and stops well. It is quiet in fast-forward flight, but at high headspeed (85%), it wags violently when I pull up at the end - really violently. To get rid of this, I need to drop the gain way down so the tail wags slowly and doesn't hold well.
how to address this, so I can use the right gain level please ?
PostPosted: Sun 07. Jun 2015 17:47:46
Great,
most probably you will need to configure Piro Consistency parameter. If it is too low, rudder will not hold even with too high gain.
What is your current value?
PostPosted: Sun 07. Jun 2015 18:08:20
Thank you for the super-quick response and the efforts !!!!
It is set at 160. (default ?)
PostPosted: Sun 07. Jun 2015 18:43:40
You can try for example 165 - 170.
Users browsing this forum: No registered users and 38 guests
