It is currently Fri 22. Nov 2024 19:38:26
[ 8 posts ] |
darokis
Posted: Fri 05. Jun 2015 14:50:03 |
Please explain in depth a difference between stabilization mode and rescue mode. Are these modes the same with an exception that rescue mode adds a positive pitch ?
Is it possible to setup a spirit so the heli flies like a drone ? always self level itself ?
Jman841
Posted: Fri 05. Jun 2015 19:06:37 |
Yes, stabilization makes it fly like a stabilized quadcopter (Not sure what a "drone" is).
Rescue mixes pitch with stabilization to save you from a crash.
darokis
Posted: Fri 05. Jun 2015 19:18:04 |
That means that I can have a switch assigned to stabilization and that switch can be on all the time ? Heli will level itself once sticks are released (centered) ?
Posted: Sat 06. Jun 2015 10:06:16 |
Yes, you are right.
davidgrajko
Posted: Sat 06. Jun 2015 18:55:38 |
So if I activate rescue it will act exactly the same as stabilization just not add positive pitch ?
Posted: Sat 06. Jun 2015 19:01:57 |
With the latest version stabilisation behavior is different so flying with it is even more comfortable so it is not similar to the rescue.
For bailout we recommend the rescue mode. If you want to learn slowly basic maneuvers you can use stabilisation mode.
darokis
Posted: Sat 06. Jun 2015 21:37:16 |
Just to be clear in:
1.stabilization normal mode when i flip the heli upside down and release the sticks it will go back to upright level position (skids down)? 2. stabilization acro mode when i flip the heli upside down and release the sticks it will level itself being upside down (skids up) ?
Posted: Sat 06. Jun 2015 21:42:11 |
Yes, exactly as described.
[ 8 posts ] |
Users browsing this forum: Google [Bot] and 38 guests |
