It is currently Fri 22. Nov 2024 19:47:09
 Post subject: Preset failsafe
PostPosted: Thu 04. Jun 2015 12:30:47
I was wondering if it is possible to have preset failsafe when using only dsm2 satellites with the new 1.2 firmware? If so, how do you set them? Have not been succesful in my attemps, only throttle works as it should, e.i going to hold.
 Post subject: Re: Preset failsafe
PostPosted: Thu 04. Jun 2015 13:52:10
Yes,
you can configure failsafe values for all channels. This can be done during bind process. You only have to set all channels as you wish and start the binding.
PostPosted: Thu 04. Jun 2015 14:12:58
Thank you for the quick response. Okay, will try again then. Do you follow the Spectrum protocall for preset failsafe binding? I mean as soon as you power up with the bind plug and the sats start blinking, do you pull the bind plug and then power up transmitter with sticks in the position you want or am I doing it wrong? Oh and should I wait for the Spirit to initialize before powering up the transmitter and starting bind?
PostPosted: Thu 04. Jun 2015 14:16:17
You are doing it right, but bind plug can be plugged for whole binding process. Just before next initialization it should be removed.
You do not need to wait for anything.
If Status LED after binding process is turned off, then all is OK.
