It is currently Fri 22. Nov 2024 19:32:43
 Post subject: Spirit on JR Vibe NEX E8
PostPosted: Sat 09. May 2015 13:58:30
Any suggestions on settings? Not sure which preset would be the best starting point. Tried Logo600 but the tail ratio setting seems off for the vibe.
Futaba BLs252 on cyclic
JR 8900G on tail.
jeti mezon 130HV (internal gov)
The set up is all donebut my buddy who I am helping reported crazy wags at 1800H/S,
a little less wag at 2k and 2,2k!
cyclic gain now at 60% and tail lowered from x 1,4 to x 1,2. Anything else I can or should look out for.
thanks in advance
PostPosted: Sat 09. May 2015 14:37:48
The most imprtant is to configure Piro Consistency parameter properly. If it is too low, you will observe fast tail oscillations but the rudder will still not hold very well.
If it is too high tail oscillations may be in the higher extent, very agressive but with lower frequency.
Also I recommend to set rudder delay to low value.
With this ESC user are reporting not very good experiences with the internal governor, maybe this is the issue. Governor plays important role in the rudder performance too. Is RPM holding well?
Can you describe tail wag more precisely?
Users browsing this forum: Bing [Bot] and 41 guests
