It is currently Fri 22. Nov 2024 18:29:05
PostPosted: Sun 03. May 2015 20:20:44
when using the bluetooth with the Android App, I can see all the tuning values but cannot change all of them.
For instance the rudder limits, values displayed are the good ones but I cannot change them.
Is there a way to change these parameters with bluetooth?
If not, why?
Joce
PostPosted: Sun 03. May 2015 21:08:58
Hello Joce,
probably, app is in basic mode "basic mode" (do you see key icon on top right?). For disable basic mode, go to connection sreen, and than open context menu (or click on the tree blue dots) and disable basic mode.
Logo 600 3D -> Spirit FBL
Spirit settings Developer
PostPosted: Sun 03. May 2015 22:19:43
Ok thanks !
Yes I found it. Very good :)
PostPosted: Mon 04. May 2015 13:03:35
The reason i know some parameters to gray out is because they can only be changed in the primary bank 0 when you wouldn't want the values being different between banks, such as piro comp and 6 degree setting.
Users browsing this forum: No registered users and 37 guests
