It is currently Fri 22. Nov 2024 19:02:18
PostPosted: Mon 22. Sep 2014 21:57:21
I can't open the Log.
There is the following Error Message:
Sure, i have installed a PDF reader, the normal Adobe Reader.
I also installed another PDF reader, but i always get this error.
Can somebody help me?
Thanks,
Piotre
PostPosted: Mon 22. Sep 2014 22:06:43
Send me the log by email i will pm my address
PostPosted: Mon 22. Sep 2014 22:11:41
From unknown reason your PDF reader is not registered in system so program can't associate PDF files to open it.
You can try to reinstall PDF reader for All Users in OS.
Alternatively you can open Log files from Documents directory.
PostPosted: Mon 22. Sep 2014 22:17:53
yeah, i did not know that the software saves the files in that directionary...now i found serveral Logs there :)
I can just open them with a double click...no problems...
perhaps the "all Users" is the problem?
I will try to install the adobe reader again and then i will select "for all users".
Thanks!
PostPosted: Sun 03. May 2015 17:46:11
I got the same problem (spirit soft unable to find a valid pdf reader). I tried to desinstall/reinstall Acrobat reader but uselessly. Did you find out a solution?
Thanks in advance
PostPosted: Sun 03. May 2015 21:24:44
Hi igloo,
what is language in your operating system and what version do you use?
PostPosted: Sun 03. May 2015 22:15:19
Hi, tks for this sunday reply ;)
As for your questions : Windows 7 pro, french
PostPosted: Mon 04. May 2015 13:18:21
Sryl ? I would recommend that u guys solve your computer related issues by yourself !
Geez , sometimes ......
PostPosted: Mon 04. May 2015 13:34:03
igloo: Could you check your Documents directory if the logs are present there, please?
Most probably there is missing some association between PDF and reader so the software can't open the file.
PostPosted: Mon 04. May 2015 18:52:52
Yes, the log are actually present, no pb on this side. Association with a pdf reader is set as well (picture hereunder)
I have removed the Acrobat reader, then install a new one : not better
Users browsing this forum: mainstreet and 79 guests
