It is currently Fri 22. Nov 2024 18:59:55
PostPosted: Wed 22. Apr 2015 9:03:12
when I use the rescue function (Acro) the tail gets an quick oscillation.
How can I change this? (Voodoo600 BLS251 Servo)
Regards Jens
PostPosted: Wed 22. Apr 2015 9:25:48
What is your gyro-sense?
Maybe gyro is set to high.
It also may help, if you post your settings here.
PostPosted: Wed 22. Apr 2015 11:01:34
you have to configure Gyro Gain to the same value as in your conventional flight. So if you are using +60% for normal flying, for the rescue you have to set -60%.
You can also decrease little bit for the rescue.
PostPosted: Fri 24. Apr 2015 10:10:58
I have decreased the value and everything is fine :D
Users browsing this forum: mainstreet and 69 guests
