It is currently Fri 22. Nov 2024 18:36:07
PostPosted: Mon 20. Apr 2015 18:29:10
The tuning guide says that rudder delay can be 0 for "ultra fast servos". This isn't very precise. Is 0.032 sec/60 fast enough 0 delay?
I think the guide should be changed to reference specific speeds instead of vague descriptions.
PostPosted: Mon 20. Apr 2015 18:53:33
Thanks for the idea.
There is just problem that it can't be explicitly described, because even if servos are rated for the same speed they can behave differently.
But I believe we can specify it more.
You can try value of 0. It shouldn't be higher than 5.
PostPosted: Mon 20. Apr 2015 19:34:26
Specifically my tail servo is a BK Servo DS-7005HV on a Compass 6HV Ultimate.
PostPosted: Tue 21. Apr 2015 18:37:17
Another question would be, how should you expect your heli to respond to know your delay is too low?
PostPosted: Thu 23. Apr 2015 7:28:05
With slower tail servos you will get tail oscillations and overshoot during agressive stops when Rudder Delay is too low.
So Rudder Delay is working like a smoothing parameter and is doing servo to respond "faster" with our algorithms.
On the other hand if the value is too high you can get oscillations with fast servos too (mostly in fast forward flight).
Users browsing this forum: No registered users and 67 guests
