It is currently Fri 22. Nov 2024 14:23:56
Posted: Mon 20. Apr 2015 13:40:11 |
Ah, then I recommend to increase Gyro Gain. What is your RPM? If it is too low, then rudder is mechanically not able to hold the rudder.
Also it is important to configure Governor or throttle curve correctly so the RPM are holding well too.
pabloK
Posted: Mon 20. Apr 2015 21:49:09 |
I configured governor on the castle edge HV80 at idle up 1: 2388 idle up 2: 2459
I tried the funnels on idle up 2
do you recommend another setting? more RPM or maybe V or flat curve ?
thanks
Posted: Mon 20. Apr 2015 21:56:53 |
RPM is OK.
First from all you should try to increase Gyro Gain as high as possible without tail oscillations. Then if the rudder will still not hold perfectly increasing Piro Consistency is needed. It shouldn't be higher than 190.
pabloK
Posted: Mon 20. Apr 2015 22:34:41 |
great, I will try
what do you think of the other parameters in order to get a smooth and precise feeling flying style?
Posted: Tue 21. Apr 2015 9:28:19 |
I recommend to set 25-30% expos in your transmitter, configure Flight Style to 6-8, increase Elevator Filter to 2-3 and set frequency for the cyclic servos to 200Hz.
Users browsing this forum: Bing [Bot] and 48 guests |
