It is currently Sat 23. Nov 2024 4:35:29
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Wed 25. Mar 2015 18:18:51
Very nice. Thanks for sharing your photos!
Did you tried it in the air?
PostPosted: Wed 25. Mar 2015 20:30:40
Not just yet, doing final setup soon levelling the head and setting up stability mode before rescue I will update the thread once its up I'll try for a vid too
PostPosted: Sun 19. Apr 2015 22:37:36
So a successful maiden, although it seems my voltage regulator is failing and won't complete the bec test Without spirit reinitialising but I did some nice slow 8's and pitch pumps and its very stable will replace the power system and give it a good test next time
PostPosted: Mon 20. Apr 2015 8:44:22
Thank you very much for the info.
Oh yes, sufficient supply voltage is very important else it can cause major failure in the flight.
PostPosted: Sat 19. Sep 2015 15:52:36
Hi Im setting one up, Ive got one on electric, but cant find any where to plug in throttle servo on my nitro, eg on elec pitch and throttle are in one now I have a 5th servo, Can you help. John
PostPosted: Sun 27. Sep 2015 8:42:03
Hi, for future reference, if needed. You can turn the plastic electronic mount upside down and then you have a flat surface, not the slope. Still fits under the canopy.
For the connections, I will check when I get home and confirm the throttle position. I've got it mounted on a 600N.
PostPosted: Sun 27. Sep 2015 10:10:27
You can connect throttle servo to the AUX port in the same way as ESC, but you will need to use Y-cable to connect power to the unit when you want to use only Spektrum satellites.
Users browsing this forum: Bing [Bot] and 55 guests
