ZeXx86 wrote:
if you can send more details about your helicopter I can give you some recommendations what to set.
What servos are you using?
On Cyclic FS0521HV RJX HV Servo
Tail: Futaba Bls 251
It is important to configure Piro Consistency parameter for your helicopter too, else tail can't hold properly.
For Whiplash it should be approx. 170-180.
Ok i check it when im at home
Rudder Common Gain for this size of helicopter should be at least 1.2x.
Ok i change
Can you describe "very bad" feeling of the cyclic?
Rotations (flips/rolls) were slow? Was it unstable? Have you observed oscillations?
At the test day we had wind gusts. The heli was not stable on cyclic against the wind.
No oscillation.
You have to hold against the wind gusts. I don't know how to describe.
I use other flybarless systems like CGY750, vortex vx1n, microbeast but the feeling was unstable at the Spirit.
Stabilisation mode and so on is off.
If you Pitch up the Whiplash it rolls a little to the right site.
Not straight up in the air.
You can upload here your settings so it could be easier to help you.
I upload the settings at the evening.Is it possible to check the vibration level with the DC-16 Radio?Thank you for the fast help!
