It is currently Fri 22. Nov 2024 14:33:59
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Mon 30. Mar 2015 20:39:11
Hi
I reinstall everithing and put a new spirt and anew satelite unit on this Kit
Everithing runs smooth, but rescue is unpredictable.
At first spool up and in hover, I tried and goes OK, after some maneuvers, I put in hover again and recue goes back and left!!!!
I land the heli and tried and swash goes back
Please help
I bought the spirit because of the rescue mode
thanks
PostPosted: Mon 30. Mar 2015 21:08:55
Make sure that piro optimization parameter is correctly configured.
If not, then it will cause unpredictable behavior, so it is very important.
PostPosted: Tue 31. Mar 2015 0:27:06
can you send me any guide, video, link or something to see that?
because it is very dificult to see in the bench and with the cable connected
PostPosted: Tue 31. Mar 2015 23:41:17
FLYING GREAT, RESCUE TOO !!
For improve security in RX matters, and for obvius reasons, what RX do you think is better for this 600L kit?
this one:
http://www.horizonhobby.com/helicopters ... -spmar9310
or this one but with sattelites for carbon fuse?
http://www.horizonhobby.com/radios/airc ... -spmar9020
http://www.horizonhobby.com/radios/airc ... er-spm9646
thank you
PostPosted: Wed 01. Apr 2015 12:17:07
this one:
or this one
Hi, pabloK
I think, these "Carbon Fuselage antennas" don't help much on a 3D Helicopter which does not have a real fuselage.
You would need to proper mount these long antennas to be clear of the chassis.
3D heli is different than a plane, where you want to mount the sats inside and let only the antenna stick out.
If you want a full receiver instead of 2 sats I would take one with SRXL support (X-Plus in Spektrum speach)
This gives you an option for a single-line connection (When Spirit is supporting "X-Plus" in the future)
Security:
If one single cable of a "Standard receiver setup" fails you aren't any better than if the "single-line connection" fails.
In theory 2 Sats may be more secure than a single receiver, but that depends heavily on the interna of the FBL and the used cables.
ZeXx86 may comment about how secure Spirit can handle a 2 Sat setup.
PostPosted: Wed 01. Apr 2015 17:36:03
Great info
Now I have a spektrum AR8000 Rx wiyh one sat.
I have the cable for second sat directly to spirit, but i do not know if this is better than a conevntional receiver.
Please, let me know
thanks
PostPosted: Wed 01. Apr 2015 17:38:02
Support for X-Plus will be added soon.
pabloK: If you are use conventional receiver, then satellite must be always connected to this receiver. If it is connected to the unit, then it is useless.
PostPosted: Wed 01. Apr 2015 22:05:56
I will simplify my question
what do you recomend?
A standard spektrum AR8000 Rx that have one satellite or 2 sattelites direct to the unit spirit (on to the side and one with the adapter cable v2)
If it is the option of the satellites to the spirit, can I use to power the unit the AUX port ? As red and black connected to a 2S lipo and white (signal) connected to the ESC ???
PostPosted: Wed 01. Apr 2015 22:32:53
I recommend to use classic receiver - this is recommended by Spektrum too.
For small models (450 size) satellite is fine because of weight.
But everybody have different preferences.
If you want to use battery + satellites for powering the unit and servos, you have to unplug red wire from the ESC cable (if your ESC has internal BEC).
PostPosted: Thu 02. Apr 2015 1:39:46
great. thank you
Users browsing this forum: Bing [Bot], Google [Bot] and 37 guests
