It is currently Fri 22. Nov 2024 13:56:53
[ 8 posts ] |
sogum
Posted: Fri 27. Mar 2015 20:02:58 |
I have a problem with me brand new newer flown spirit unit. Seting it up worked fine I had no problem.
When I started the heli on the backyard for a test hover it seems like it initialized ok but nothing happens when I move the sticks. Lifting the heli by hand tilting it the gyro and servos working ok.
Back on the bench trying with a different sbus inverter cable also tryed anohter receiver but same story. Everything ok exept for the unit dont react on stick input. Any ideas what could be wrong?
Posted: Fri 27. Mar 2015 20:08:09 |
make sure that S-Bus inverter is oriented correctly.
Shorter end of the cable should be connected to the receiver, while longer to the unit (RUD port). Also make sure that your receiver is configured to Futaba S-Bus.
sogum
Posted: Fri 27. Mar 2015 23:34:20 |
Hi The the inverter cable conected right way dubbel/trippel checked. Also configured to sbus. As mentioned in first post everything was fine until spool up.
Posted: Fri 27. Mar 2015 23:38:54 |
Ah, very strange. Yan you check status LED on your receiver? There should be Green color if transmission is OK.
sogum
Posted: Mon 30. Mar 2015 16:41:14 |
The receiver is fine, the throttle chanel is working ( direct from esc to reciever). Also tryed with an another reciever, same story. I've ordered a brand new usb inverter cable from you, see if it helps.
Posted: Mon 30. Mar 2015 19:10:22 |
Maybe you can try to spool up the motor without blades and check what is really happening.
There could be for example just problem in the transmitter settings. For example after enabling throttle, rescue mode is activated.
sogum
Posted: Sun 12. Apr 2015 11:38:16 |
Problem solved. After mounting the new cable everything worked fine. Someting must have happened with the old usb cable (tarot). Very good flying gyro by the way.
sogum
Posted: Sun 12. Apr 2015 16:00:09 |
Great, thanks for the info!
[ 8 posts ] |
Users browsing this forum: Bing [Bot] and 41 guests |
