It is currently Fri 22. Nov 2024 18:52:59
PostPosted: Sun 08. Mar 2015 4:21:27
i have checked piro and that is correct
i will check the stab after flight and see what the swash does
PostPosted: Thu 19. Mar 2015 20:36:20
what can you do if the Piro.Option OK, vibrations do not exceed a maximum of 12 but the swashplate tilts heavily after the flight to the right.
What do I do?
please excuse my bad english, google translator.
greeting Ralf
PostPosted: Thu 19. Mar 2015 21:05:39
can you check point 2) - alignment of the unit?
Do you fly some acrobatics or harder 3D?
PostPosted: Thu 19. Mar 2015 21:24:50
2. to have different pads have tried. And the position of the Spirit also changed already on the Heli.
I only fly flight no 3D.
beginner
when I start mode in the stability it works.
Excuse my bad english
greeting RAlf
PostPosted: Thu 19. Mar 2015 21:34:41
Thanks for the info.
Can you please verify pirouette optimization once again?
If you are doing some additional settings it may need to be changed.
PostPosted: Thu 19. Mar 2015 21:42:18
Hi Ralf
it may be still vibrations which you would only see with the blades mounted.
or:
http://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=494
Manfred
PostPosted: Thu 19. Mar 2015 21:54:26
the pirouette optimization I have before and after the flight check is OK
it is a TRex 700 clone
The rotor blades are new, main and tail rotor blades, blade shaft bearings, all new bearings
Blades balanced.
PostPosted: Thu 19. Mar 2015 22:02:48
Can you measure vibrations on Y - Aileron axis with tail blades on, please?
Mostly tail blades are most problematic, so it can add huge spikes. Then we can be sure it can't be vibration problem.
Do you have latest 1.1.0 version?
If you do not see High Vibration event in the log, than it should be OK.
PostPosted: Thu 19. Mar 2015 22:14:02
I will do it tomorrow with tail rotor blades s test
Log flight after the Last
PostPosted: Thu 19. Mar 2015 22:21:35
Thanks for the log.
OK we will see then.
Did it happened earlier or it is new problem?
In the worst case I can send you some unit to compare or you can send us the unit to recheck if you wish.
Users browsing this forum: mainstreet and 80 guests
