It is currently Fri 22. Nov 2024 6:41:49
 Post subject: Wishlist (Bluetooth app)
PostPosted: Fri 28. Nov 2014 2:50:37
Bluetooth app wishlist
1. Make it easier to see and change the parameter values in bank 0, 1, and 2. What would be nice is to add a tab that displayed a table of values you could see and change, all on one screen:
Parameter Bank0 Bank1 Bank2
Flight style 4 4 4
Cyclic gain 50 47 44
Cyclic agility 8 8 8
etc
etc
etc
2. Add an "exit" button in the app that disconnects and exits the app. Exiting the app now using the back arrow does not disconnect (blue light is still solid). I have to manually kill the app to disconnect.
PostPosted: Fri 28. Nov 2014 17:25:22
Flight style 4 4 4
etc
etc
etc
Now it works like this, just tabs are not horizontally but vertically and are opened by sliding.
this disconnecting is not recommended because it does not switch on the transmitter-controlled banks. it is sufficient to reopen the application and disconnect BT.
developed version has functions caution when unsaved changes
Logo 600 3D -> Spirit FBL
Spirit settings Developer
PostPosted: Mon 01. Dec 2014 2:51:44
Warning when changes have not been saved and bank comparison are great. When will they be in the Android application? The version on my phone is 1.0.25-2 and it does not have the bank comparison function.
PostPosted: Mon 01. Dec 2014 12:46:01
im sorry :(, this is develop version 1.0.26, will be release same time as firmware.
PostPosted: Wed 11. Mar 2015 12:30:16
Is there any chance that the android app supports connection through usb too besides bluetooth? I recently bought a relatively small tablet with a screen which is way bigger than my phone's but it has no bluetooth (so the app cannot be installed "your device does not support it") but it has usb! It would be way more convenient than carrying my laptop to the field...
PostPosted: Wed 11. Mar 2015 13:25:10
Support USB (OTG cable) was never intended, but I'll check if it's at all possible
PostPosted: Fri 08. May 2015 13:58:36
It's been quite some time now. Any news?
PostPosted: Sat 09. May 2015 15:02:41
+1 (thanks in advance for the reply)
PostPosted: Sat 09. May 2015 20:23:32
Hi, it is possible connect to spirit over FTDI -> OTG but i have to rewrite app core in android apps :(. it will not be quickly :((
PostPosted: Sat 09. May 2015 21:41:01
Tks for this answer and your work.
Users browsing this forum: No registered users and 14 guests
