Zeks already answered in another forum. In case anyone was looking here and he doesn't have to cross post
I guess it is servo issue (probably elevator servo)
There is no parameter that can do such thing in the unit.
If you are doing pitch pumps on the ground and your cyclic is perfectly level, then most probably it is not related with settings at all.
You can only increase Elevator Filter to minimize elevator bouncing, but it is not solution of the problem.
Servo may stop working when it is warm.
I recommend to not fly at all as the helicopter can crash at any moment.
To be sure, you can send your settings so I can review it.
__________________
