It is currently Sat 21. Sep 2024 8:36:08
Hififreak
Posted: Sun 08. Feb 2015 23:49:55 |
Hallo,
i build my first Heli (KDS Chase 360), at first i take the AR610 but i change to the Spektrum AR8000 Receiver and i need the PWM connection from Hobbywing Platinum 50 to Ar8000 and from AR8000 to the Spirit. i have the Spektrum DX6 Black edition
Sorry i am a beginner
Regards Ritchy
Posted: Mon 09. Feb 2015 8:33:07 |
Hififreak
Posted: Mon 23. Feb 2015 13:01:18 |
i can make what i want, but it does´t works.
I take the ar610 and ar8000
Posted: Mon 23. Feb 2015 13:02:55 |
can you describe what does not work?
Make sure that PWM receiver type is configured in the software.
Hififreak
Posted: Mon 23. Feb 2015 14:36:17 |
The connect from the receiver to the spirit doesn't work
I test the receiver, i take the servos into the receiver and there are works.
But not with the Spirit.
Your manual in english is to deferent to the in german.
I think the mistake is when i bind the system, but i can't find the correct way
Posted: Mon 23. Feb 2015 14:52:34 |
OK, please can you take a photo of your connection?
This can be much faster to determine where is the problem.
Hififreak
Posted: Mon 23. Feb 2015 15:18:48 |
when i change to PWm the rud works, but the other ones not
but this is not Spektrum DXms2 with satellites
did i need the spektrum adapter for the ar 8000
but i test with the ar610 there are the thame problem
Posted: Mon 23. Feb 2015 15:22:29 |
You should set connection type to PWM if it is normal receiver connected with three cables that are included in the box of the unit.
Hififreak
Posted: Mon 23. Feb 2015 18:02:29 |
i have a SPEKTRUM DSM2/X SATELLIT recever, the protocol are DSMX
Posted: Mon 23. Feb 2015 18:07:02 |
It does not matter which satellite you are using, if you want to use AR8000 (+ satellite) it must be always PWM connection type.
Users browsing this forum: Bing [Bot] and 11 guests |
