It is currently Fri 22. Nov 2024 8:44:01
Post new topic Reply to topic  [ 13 posts ]  Go to page Previous  1, 2
 Post subject: Re: Bailout and tail
PostPosted: Wed 28. Jan 2015 18:27:22
I'm being stupid but how do I set the gain to negative on the sensor tab... All I have is sensitivity (Cyclic and rudder common gain, both positive). Reverse and rotation speed...
PostPosted: Wed 28. Jan 2015 18:36:18
After unassigning Gyro Gain function in General/Channel Assignment it will be visible in Sensor Tab. It is hidden now.
 Post subject: Re: AW: Bailout and tail
PostPosted: Wed 28. Jan 2015 19:18:45
ZeXx86 wrote:
If you want to switch between conventional flight, stabilisation and rescue (with only one switch on your TX), you can do so with unassigned Gyro channel, so you can configure Gyro Gain (in the software - Sensor Tab) to negative positions for Bank 1 and 2, but for Bank 0 it will be positive.
So activation will be performed with Bank switching only, but Gyro Gain will be configured in the software.
There is also the possibility to switch the GyroGain to negative by using a mixer on the same switch used for the banks. I have done so - it is working great.
Gesendet von meinem GT-I9515 mit Tapatalk
Users browsing this forum: gerry and 30 guests
