It is currently Sat 21. Sep 2024 9:30:39
[ 4 posts ] |
scott s
Posted: Mon 12. Jan 2015 0:09:39 |
Man there is a total lack of info on using jeti rx's in udi format. Does anyone know the correct settings. Is it auto and computed? 5 to 20ms computed etc. I know that in ppm on newesr firmware that fail safes in the rx do not work in direct mode. At least on my r4 rx's it did not. I do not even recall seeing fail safe settings when in direct. Who is using what LOL!
taosgraveyard
Posted: Mon 12. Jan 2015 13:35:10 |
I am using computed, 10 ms On jeti, fail saves work in direct mode for the first 4 channels. More than that, no. That's why I am using computed.
Be sure to use latest Jeti rx firmware and latest tx software
Even though UDI is a digital protocol with checksumming and error handling, I keep the rx to spirit line as short as is practical.
Posted: Mon 12. Jan 2015 14:07:16 |
it should work in nearly any settings. Failsafe is always handled by transmitter (except Spektrum satellites).
pkotatko
Posted: Sat 17. Jan 2015 11:49:16 |
I am using direct, 10ms and 100Hz frequency. I did first ten flights today with Jeti and R9. Latest FW in both. I don't using FS, because ESCs ( Jive and Kosmik ) are switching off in case of lost signal. That's all I want. Petr
[ 4 posts ] |
Users browsing this forum: Google [Bot] and 0 guests |
