It is currently Mon 25. Nov 2024 11:10:01
[ 5 posts ] |
akabud
Posted: Fri 09. Jan 2015 19:56:43 |
I've seen comments that say set the collective pitch in rescue to 100% so it will work faster. Is this correct or does the pitch setting only affect how fast it climbs after it levels? For instance, if I set pitch to 55% will it level just as fast and then hover? I don't want to slow the recovery but I don't think it needs to climb much.
Posted: Fri 09. Jan 2015 20:05:02 |
It is true, that more collective can rescue the helicopter with greater chance if you can fly in low altitude. If your helicopter is moving to the ground, higher collective will stop the movement faster (and then will climb faster).
Jman841
Posted: Fri 09. Jan 2015 21:03:22 |
I think what he is asking is, does the collective setting change the rate that the heli will get to level.
So if the heli is knife edge and then he hits rescue at 60% will it get to level (flat) at the same speed as 100%? Or will the rate that the heli will turn to get flat also be less?
I am not 100% sure but I believe the rate that it uses to get level is determined by your cyclic ring limits, not by the collective. The collective is just how much is applied after level.
Posted: Fri 09. Jan 2015 21:05:34 |
Yes, that is true.
akabud
Posted: Fri 09. Jan 2015 21:16:23 |
Thanks that answers my questions. It works as I thought it should. But I hadn't considered that more collective is helpful if the heli is diving fast. It takes a lot to stop that downward momentum.
[ 5 posts ] |
Users browsing this forum: Bing [Bot] and 10 guests |
