It is currently Fri 22. Nov 2024 0:28:58
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Bugs
PostPosted: Thu 18. Dec 2014 15:28:12
Thanks for your info.
We will test it again in short time with Tarantis and hopefully it will be sorted with OpenTX developers.
You do not have to record it. I recommend to disconnect the battery as soon as possible because servo can burn itself.
PostPosted: Fri 19. Dec 2014 14:48:41
I am curious to know why this effects yours after it was rescued on mine and others? What version of OpenTx are you running? What Rx do you have? there has to be some difference.
PostPosted: Mon 22. Dec 2014 23:22:58
I find it extremely hard to believe it's a Taranis/OpenTx problem. Do you mean no other brands of receivers have this problem?
Anyway, I use X8R as a receiver and I'm running 2.0.13 version of OpenTx.
PostPosted: Tue 23. Dec 2014 16:57:05
No sure the problem is related to opentx. Opentx send data using PXX protocol to X8R and there is firmware in X8R that prepare the sbus output data and frame. Cant be the issue in the firmware then in OpenTX?
PostPosted: Tue 23. Dec 2014 20:01:34
It did it again today. I went out for some fine tuning including gov gains and revo mix and I saved ~15 times. It did it once. On bluetooth connection this time. This is the first time I use the Bt by the way; not that it matters anyway...
PostPosted: Tue 23. Dec 2014 20:42:57
Only to understand.
Did you fine tuning Gov gain ?
But Spirit (unfortunately) doesn't have Gov at the moment !!!!!
Or you are speaking of ESC Gov ??
Mirco
PostPosted: Fri 26. Dec 2014 0:02:11
gelatmi1 wrote:
Only to understand.
ESC of course. But I also tweaked the revomix for best results. So I saved a lot of times...
Users browsing this forum: No registered users and 41 guests
