It is currently Fri 22. Nov 2024 9:01:27
 Post subject: Firmware version ?
PostPosted: Sun 23. Nov 2014 17:48:21
how can I determine which firmware version isn on the spirit?
I thought, i have flashed it to 1.0.25.1, but displayed is only the "old" version 1.0.25.
Btw. is there a difference in the software between 1.025.1.and 1.0.25 ?
Friedl
 Post subject: Re: Firmware version ?
PostPosted: Sun 23. Nov 2014 19:07:04
you can determine it by filename you have downloaded and flashed.
Software and firmware always contains version.
PostPosted: Sun 23. Nov 2014 23:38:19
this is already clear, but to be sure that the "correct" version is on the unit, i had to flash it again.
It would be nice, if the whole number is dispayed in the software.
Friedl
PostPosted: Mon 24. Nov 2014 18:04:07
Hi
I agree on this one i have flashed mine twice as they show as being 1.0.25 and so does the PC software, yet i no they are all running 1.0.25.1.
Why do they not show full verson?.
Regards Alan
PostPosted: Mon 24. Nov 2014 18:07:16
in the following version it should be improved, so full version will be displayed.
At the moment there is protocol limitation.
PostPosted: Mon 24. Nov 2014 18:26:40
Thats great news thanks for your response.
Regards Alan
PostPosted: Mon 24. Nov 2014 21:45:26
Just delete zero from version number: 1.25.1
DX9 - Chase 360 - Spirit
PostPosted: Mon 24. Nov 2014 21:49:39
We will use all these subversions, so all current ones are required.
PostPosted: Mon 24. Nov 2014 22:47:36
ZeXx86 wrote:
in the following version it should be improved, so full version will be displayed........
also thanks for this information!
Friedl
Users browsing this forum: No registered users and 23 guests
