It is currently Fri 22. Nov 2024 8:37:49
 Post subject: Setup questions
PostPosted: Sat 15. Nov 2014 16:22:29
I am almost finished with the setup but I still have 3 questions or problems.
1. my swash is not moving up and down whe I move the throttle stick.... Not sure what I am doing wrong since everything else works - all the setup, when I give aileron, elevator or rudder all servos move accordingly. The stab correction works in the right direction on all axis. But with the Spirit connected to PC or disconnected, there is no up and down movement of the swash when I move the throttle stick????
2. please explain again how the swash is suppose to move durin Piro setting. Or how it is not suppose to move if it is reversed. I read the manual many times and it still is not clear to me how it should move correctly when I check it by yawing the heli.
3. this might seem like a stupid question, but how do I assign a switch for the bailout? Set everything up in the software but saw no description on how to assign that to a switch.
i'm using a Taranis with a X8R Rx from Frsky. Set to H1.
Thanks again for the hellp
 Post subject: Re: Setup questions
PostPosted: Sat 15. Nov 2014 16:34:23
1. this is because the bailout is activated right now. Check gyro gain and change it to be positive.
2. check this: https://www.youtube.com/watch?v=zZzZFpPFkew it is same as for Microbeast
3. you can assign momentary switch to change your gyro gain to negative values. This will activate the bailout - you should see HF instead of HL in the diagnostic tab
PostPosted: Sat 15. Nov 2014 16:41:29
Thanks. Will try and let you know.
Users browsing this forum: gerry and 34 guests
