btheli wrote:
That is what counts! I'm at 2.012 as well. I've been working on my model too and might maiden today...we'll see. Looking forward to seeing your updated eepe. I think I'm still doing too much in the mixer and not enough in the inputs, but in the end it may not really matter
I think when you see mine, you will be happy.. the only thing I have in the inputs is the inputs & expo..
Everything else is in the mixing... Don't forget your subtrim & I had to change the PPM centering to the get the right pitch value..
Ok!!
Spent some time on this!!!
Hope I have not missed anything.
Attached are two files.
Trex450-Spirit(Yak).zip [1.09 MiB]
Downloaded 83 times
The first is an example setup .eepe for a TRex450 using a Spirit FBL Unit.
There is also an included folder for the sound files used, including the "Yoda" theme I have for this Heli.
Check the readme.txt for the full details including the description of the bailout, bank switching, gyro adjust, & voltage, gyro, throttle settings audio announcement.
Test it out in the TX sim first!!
PC-Joystick(Yak).zip [6.51 KiB]
Downloaded 82 times
The second file is a work in progress for PC games & Heli-X
I have been using Heli-X with the Taranis and USB cable in joystick mode.
Also been flying Heli's in Battlefield 4 with Taranis..
To use this, power on the TX, select the joystick model & connect the USB cable.
Windows 8 automatically detects the Taranis "joystick"
Good Luck!
Cheers,
Yak,
