It is currently Fri 22. Nov 2024 8:08:56
The Mechanic
Posted: Fri 14. Nov 2014 23:12:20 |
I would like an exchange actually as most people really like the Spirit and I think I will too. I do trust you and tried all your suggestions but as I said I don't use DSM2; it should work fine with DSMX. Please give me the return address you would like shipped to.
Posted: Fri 14. Nov 2014 23:14:54 |
OK, you should receive private message. Address is also mentioned on the box of the unit.
The Mechanic
Posted: Fri 14. Nov 2014 23:16:47 |
Oh, and I was going to ask, maybe you missed in previous post; is it true that all ports except ELE/PIT/AIL and SYS share negative and positive bus? You should be able to plug 5V power into any port except ELE/PIT/AIL and SYS?
Posted: Fri 14. Nov 2014 23:20:07 |
Yes, it is true.
The Mechanic
Posted: Fri 14. Nov 2014 23:24:32 |
Yak
Posted: Sat 15. Nov 2014 15:12:29 |
Have you tried filming the TX (with the channel outputs) and the diag screen. The guys here really helped when I and another user ran across something very weird. Have you a full RX (not sat) that you could connect with the loom to test.
Cheers, Yak.
Users browsing this forum: Google [Bot] and 27 guests |
