It is currently Fri 22. Nov 2024 20:32:42
Post new topic Reply to topic  [ 159 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 16  Next
PostPosted: Sun 09. Nov 2014 13:28:36
ZeXx86 wrote:
Perfect, good night.
Here it is time for lunch :)
Thanks guys..
Still lurking here.. winding down watching TV.. :)
Hope it's a good flying day...
Cheers,
Yak.
PostPosted: Sun 09. Nov 2014 14:39:35
Ok,
just did some testing.
I can not get any issues to happen when saving or opening the logs. I tried different saved changes about 5-10 times and opened the logs 3 times.
However, I still have the same issue when turning the tx off. Fast short servo movements.
Getting there! The save issue is resolved! Now, just to figure out why it goes crazy when the Tx is turned off.
PostPosted: Sun 09. Nov 2014 15:18:12
Thanks, could you try test15 FW, please?
Do you remember if any of test firmwares resolved such issue?
PostPosted: Sun 09. Nov 2014 15:55:32
Just tested Test 15 and no luck, Heli still goes crazy when link is lost.
I don't recall any fixing the issue with turning the Tx off.
PostPosted: Sun 09. Nov 2014 15:57:48
The saving and opening the log work well with version 15 as well. Only issue still is when Tx is powered off.
PostPosted: Sun 09. Nov 2014 16:26:53
Good, then the problem is definitively in failsafe code.
Please, try this: http://spirit-system.com/dl/fw/test/spi ... test17.bin
PostPosted: Sun 09. Nov 2014 17:04:21
No luck,
No issue with saving or opening logs (Only tested 2ce) but still the same issue when Tx is powered off.
How come this only happens when it is connected to the software?
If not connected to the software the failsafes work perfect. That seems a bit strange.
PostPosted: Sun 09. Nov 2014 17:44:50
Yes, this is very weird.
I am curious if this issue could be happened by improper grounding.
That mean notebook power supply ground and helicopter's battery ground.
But if the problem does not occur when software is not running, but interface is connected, then it must be software related.
PostPosted: Sun 09. Nov 2014 18:49:59
Let me test that for you...
PostPosted: Sun 09. Nov 2014 18:54:23
Hmm,
Just kidding, Now it is having the issue even when not plugged into the computer or never plugged in.
Let me test one of the old tests again to see if it does not do it with them.
