Hello again.
I have done the following..
Flashed back to test5 to see if I could repeat the symptoms.
Power cycled heli & restarted software.
Checked the diag screen while moving the sticks.
Turned off TX,
Checked diags (failsafe's correct)
Clicked on logs.
The tail servo started glitching.
Turned on TX
Flashed to test11
Turned off TX,
Clicked on logs.
[Got my phone out to record some video)
Turned off TX,
Clicked on logs.
The tail servo DID NOT glitch.
Turned off TX,
Clicked on logs.
What I have been able to repeat..
The first time I do it... there is no issue, the second time there is.
The only difference that I can think of between the times is possibly more movement in the sticks before turning the TX off.
I have uploaded the video to youtube..
https://www.youtube.com/watch?v=NCW386h ... e=youtu.be[edit]
I was reviewing the video & noticed something.
When the tail is twitching, the diag screen is reporting 118's as the value.
I'll see if I can get a screenshot.
Got it from the video..
Cheers,
Yak.
