It is currently Fri 22. Nov 2024 8:05:27
Post new topic Reply to topic  [ 159 posts ]  Go to page 1, 2, 3, 4, 5 ... 16  Next
PostPosted: Wed 05. Nov 2014 16:08:17
Tomas,
One quark I have noticed with the new software is when I assign bank switching to channel 7 using futaba sbus, after it asks me to save, I click yes, and all the servo's go crazy spazming back and fourth until i turn it off and back on again. Once I reset it, all is good and settings were saved, however, I am not sure why it does this when saving changed settings to the unit sometimes.
PostPosted: Wed 05. Nov 2014 16:12:26
This also happened when I opened the log.
PostPosted: Wed 05. Nov 2014 19:22:28
Thank you very much for the report.
This is not good, do you have throttle channel assigned?
PostPosted: Wed 05. Nov 2014 23:11:52
On my Gaui X3 I do. Throttle channel is assigned to Channel 1.
On my G570 I do not as I use the channel where it would go to power it and throttle is directly into the Rx.
Both have had this happen. Fortunately it causes no damage and the unit saves properly and all is normal after I reboot the spirit.
PostPosted: Thu 06. Nov 2014 1:49:47
This happens anytime I save or pull the logs from the unit on the X3. The Scary part is since the throttle is controlled through the FBL it starts to spin the blades up. Luckily it doesn't stay on and only moves them a little bit, but, that is definitely a concern.
PostPosted: Thu 06. Nov 2014 8:28:15
Sorry to hear about your issue, unfortunately I can't reproduce it,
but I will investigate where could be a problem.
Do you have assigned channel for Throttle in both units?
What RX/TX do you use?
Could you send me/attach your settings, please?
PostPosted: Thu 06. Nov 2014 8:48:56
I had same issue but with v24 when I opened a log
DX9 - Chase 360 - Spirit
PostPosted: Thu 06. Nov 2014 10:01:32
Could you try this firmware, please?
http://spirit-system.com/dl/fw/test/spi ... 1-test.bin
Also I recommend to download version 1.0.25.1 before the update:
http://spirit-system.com/dl/settings/sp ... -win32.exe
Thank you very much
PostPosted: Thu 06. Nov 2014 13:15:27
Absolutely, will do.
I'll make a video as well. Thanks for the excellent support!
PostPosted: Thu 06. Nov 2014 13:19:28
Here is my current file for the Gaui X3 with X4r frsky rx, Tarot S.bus adatper, Hobbywing 50 amp V3, and Taranis Plus Tx.
I am using a Lenovo Laptop running window's 8.1
X3 first setup.4ds [255 Bytes]
Downloaded 105 times
Users browsing this forum: Bing [Bot] and 28 guests
