It is currently Sat 23. Nov 2024 3:19:48
PostPosted: Tue 07. Oct 2014 10:13:00
Hi together,
i use the bluethooth Modul on my Spirit System. Connection is fine with my LG G Pad and also with my Win7 laptop. The Problem is, using the android Device i can't save changes in the Spirit System. Is there any button to save changes to device or should it save the changes automatically?
Every time i reboot the Device all changes are gone.
Using the save button (unit) on the backup menue (Win-Software, Laptop) over bluetooth is working fine.
Thanks Jens
PostPosted: Tue 07. Oct 2014 16:33:16
mobile app include same button for saving the settings as our PC software.
You can find it in context menu in the app.
PostPosted: Tue 07. Oct 2014 17:35:39
I was confused by this as well. When using your android device and using the app, You must select the menu button on your phone (not a tab in the Spirit app) and a menu will pop up that will allow you to SAVE PROFILE TO UNIT.
PostPosted: Tue 07. Oct 2014 17:43:29
Indeed there are differences. Mobile app is designed for touch screen and small displays, while with PC you can do precise clicks.
PostPosted: Sat 01. Nov 2014 11:59:43
Hi Guys,
thanks for the answers. Unfortunately there is no Button on my LG G7 Pad. I readed that Android 4.xx Devices need the Button in the App. Other Apps like Chrome or You tube have the button with 3 Points in the upper right corner. The Spirit App hasn`t that Button or I`m not abble to find it.
Someone any idea? Thank you for your help.
Falconx
PostPosted: Sat 01. Nov 2014 22:23:24
Thanks for the info.
We will try to sort it out as soon as possible.
PostPosted: Sun 02. Nov 2014 1:36:31
Do you have 3 dots in the lower right (sometimes in the left)?
Check out the video
Logo 600 3D -> Spirit FBL
Spirit settings Developer
PostPosted: Sun 02. Nov 2014 8:33:52
Here is a screenshot, the button below are "back", "home", "last apps", and "dual screen" the lg hasn`t that menue button. I dont know how many other devices are like that.
My problem is, the lg is my only Android device all others are IOS. ;)
Will there be a version for IOS devices?
Thanks a lot
Jens
PostPosted: Sun 02. Nov 2014 8:59:27
LG uses some custom panel and it looks like it ignores the command view "option menu"
Check it out here if it helps http://www.androidpolice.com/2013/11/05 ... -software/ "Homescreen, Launcher, and Navigation"
For greater comfort he probably I'll add that button to the application
apologize for the trouble
PostPosted: Thu 06. Nov 2014 22:06:44
it will be awesome if you can set the button into the app. I searched for apps wich remaps or add buttons but most of them don't work with the original rom. But its a brad new device and i don't want to flash the original rom.
For so long i will wait and maybe you can add the button in a future version.
Thanks for your help
Jens
