It is currently Fri 22. Nov 2024 7:25:49
 Post subject: [SOLVED] Bailout failed
PostPosted: Fri 03. Oct 2014 18:12:19
Hey Guys,
I tried the spirit today in my trex 550. I tried the bailout for 2-3 times and it worked very well. But after a few tries, the bailout was up side down. As i activate it, the heli went down to earth. Wth?? Is it a bug in the System, or can i check some parameters?
Best regards.
P.s. Its the newest Software on the device.
Triabolo|Kosmik 200|XNOVA 4530 XTS|MKS 960/990|Spirit Pro|REX7
Diabolo BE|Kosmik 200|XNOVA 50XX Tareq|REX3
 Post subject: Re: Bailout failed
PostPosted: Fri 03. Oct 2014 18:19:38
you should check pirouette optimization first as stated in the software and manual.
This is main reason why the rescue could fail. Pirouette optimization has to be configured properly.
If you are sure that this parameter is OK, then you can check other things.
For example if the unit is aligned to all axes precisely.
Don't worry, we are testing it for few years.
If all is correct, it will work very well.
PostPosted: Fri 03. Oct 2014 23:26:13
How are you powering the unit?
PostPosted: Fri 03. Oct 2014 23:39:17
Hey, i will check piroette optimization tomorrow morning. Ty
The unit is powered via 2 cables from rx. And the rx is connected via 2 power lines from an external 12/20A bec. So, i think that should be fine.
PostPosted: Sat 04. Oct 2014 9:40:48
Chris, let us know how it goes please
PostPosted: Sat 04. Oct 2014 13:56:08
Make sure the unit:
- initialized on a flat stable surface
- Adequate power to support a huge cyclic/collective movement on all servos
- Piro Optimization is configured correctly
- Pre-flight checks are done
- The swash direction is going the right way on the bench, if not you have to go into negative values on the pitch slider for rescue.
PostPosted: Sat 04. Oct 2014 21:49:28
I think pyro optimization was wrong. But since i crashed today, i have to wait till tuesday for the parts. Then i will give it another try.
Ty guys!
PostPosted: Wed 22. Oct 2014 8:52:57
It was the pyro optimization.
I forget to double check it after i reverted the roll.
So, sorry guys, that was my fail!! :(
PostPosted: Wed 22. Oct 2014 9:29:39
Thanks for the update Chris
Users browsing this forum: Bing [Bot], Google [Bot] and 29 guests
