It is currently Fri 22. Nov 2024 7:11:01
PostPosted: Sat 20. Sep 2014 17:16:43
I noticed a very fast wobble in the skids the other day, its probably been there all the time but its so small a movement you have to be pretty close to see it. The only way to get rid of it is to drop the head gain down to 38, is this ok? It still fly's lovely so I'm not concerned its just the software says its usually over 60. Up to 55 i get the above, over 60 i actually get a tail bob.
PostPosted: Sat 20. Sep 2014 21:45:58
Hi
Oscillation you have described is caused mostly by too soft head dampeners, play in head, too agressive or flybar blades.
Such low gain is not a problem if it works, but it should work with 60%+ gain in most cases.
For elevator bouncing you can increase elevator filter value to eliminate it.
PostPosted: Sat 20. Sep 2014 22:25:07
ZeXx86 wrote:
Hi
Thanks Tomáš
I have no play in the head, tried different dampeners no change, but i am using flybar blades, i will change them and see
Users browsing this forum: Google [Bot] and 36 guests
