It is currently Fri 22. Nov 2024 0:52:50
 Post subject: rescue question
PostPosted: Sat 02. Aug 2014 15:02:33
Question on rescue feature. Does your rescue totaly disable the cyclic when engaged? A lot of us with 3sx's set up a mix or seperate flightmode to disable at least the aileron and elevator cyclic and set it to 0. We do this because the cyclics are still somewhat active when rescue is engaged and it can be an issue!
Works great for me as my rescue is on a push button momentary switch on TOP of my aileron/elevator stick.
It keeps me from inadvertantly adding cyclic when I push the button and using the button in short bleeps works like a charm.
Thanks in advance,
Scott S.
 Post subject: Re: rescue question
PostPosted: Sat 02. Aug 2014 19:30:28
Hello!
You can set this behavior as you wish with a parameter. So it should be without a problem.
PostPosted: Thu 07. Aug 2014 19:09:39
The rescue works great.
Another amazing option and feature of the Spirit rescue mode is possibility of stopping forward moving of your heli in the rescue regime(e.g. in front of some trees, walls, etc.) . I just set the stick priority to 6 in Stabi options and than you can stop the moving heli forward by pulling elevator stick back during holding your rescue lever. Must try ! ;)
Martin
Goblin 500, Kontronik 100LV, MKS 9767HV, Futaba BLS251, Edge 503mm, Jlog2.6, Aurora9
Users browsing this forum: No registered users and 42 guests
