It is currently Wed 12. Mar 2025 12:23:50
[ 5 posts ] |
gerry
Posted: Sun 09. Feb 2025 9:54:12 |
Joined: Fri 26. Aug 2016 6:51:10 Posts: 231 Location: Austria
I noticed that the settings via Jeti transmitter are currently BIN 3.7.0 not always correctly transferred to the Spirit unit GTR 3.7.2. Everything that is changed with the PC software 3.7.2 will also be correctly transferred to the GTR 3.7.2. Please check. This case occurs when channel change F:Rescue channel 8 and F:Automatic rescue channel 9.
LG Gernot
_________________ Greetings from Gernot
Posted: Mon 10. Feb 2025 14:26:38 |
this problem could happen with older BIN file - 3.6.X and older. Can you see correct version number in the main page of the integration? You should see 3.7.2 for the Spirit firmware directly in the integration. If version is displayed incorrectly then it is 3.6.X or older actually.
gerry
Posted: Mon 10. Feb 2025 15:17:35 |
Hello Tomas, As I described before, the firmware version is up to date 3.7.2.The Jeti Bin file is also on the 3.7.0 provided by you on the homepage. Unfortunately, I can't find a higher version of the bin file.
Posted: Thu 13. Feb 2025 9:14:16 |
gerry
Posted: Thu 13. Feb 2025 11:07:21 |
Thank You Tomas
[ 5 posts ] |
Users browsing this forum: No registered users and 2 guests |
