It is currently Wed 05. Feb 2025 9:38:44
PostPosted: Tue 31. Dec 2024 2:02:02
OK, I got everything on this SAB Nitro Wired up, including an Exguard Remote Glow Driver and an Exguard Bottom plate RPM Sensor. and everything works as it should.
I'm using a Spektrum AR6610T Receiver with a Spektrum IX12 Transmitter, with the GT fbl.
However, I can't find a way to receive the Flight Pack Voltage Telemetry thru the Spirit GT fbl. I'm getting the RPM readouts but not voltage. I have a work around that I can do by using the Voltage adapter on the AR6610..
I tried Auto Config and even manually set up the Voltage on the Transmitter, but to no avail.
Should i be able to get the Voltage readout from the Spirit unit and if so what am I missing.
PostPosted: Tue 31. Dec 2024 4:47:06
I don't believe the Spirit GT has an internal voltage sensor.
PostPosted: Tue 31. Dec 2024 18:14:46
I run pretty much same setup, Spirit GT, AR6610T, NX10.
I believe the only way to get telemetry for Volts is with the supplied wire that comes with the AR6610T which works very well.
You can get Telemetry for mAh consumed tho. Believe it is under Flight Pack on the Telemetry Screen.
PostPosted: Tue 31. Dec 2024 18:47:07
Yea, I know how to get voltage with the Receiver, but then you have to spend an extra 80.00 to accomplish that.
PostPosted: Wed 01. Jan 2025 9:37:21
I don't follow.
What are you spending this 80.00 on?
The nessecary wire with connector is supplied with the Rx.
It's just a matter of running the wire and plugging it in.
PostPosted: Wed 01. Jan 2025 16:29:33
Yes ExCCHP has absolutely right !
No invest is necessary -
PostPosted: Mon 06. Jan 2025 8:29:13
Flight Pack is sent through telemetry with supported ESCs - it correspond to main battery voltage, not BEC or power supply voltage of the electronics.
You will have to use integrated capability of your receiver. Fortunately AR6610T has full support for this measurement.
