It is currently Sun 24. Nov 2024 5:15:22
PostPosted: Sat 09. Nov 2024 12:41:08
good morning to all of the forum,
I have a helicopter with rx Spektrum SRXL2 4651T connected to a Spirit 2.
As a radio I use a Radiomaster Boxer with Edge and I would like to do the integration. In the instructions I find all spektrum rx and tx or all OpenTX.
Can I do something?
PostPosted: Sat 09. Nov 2024 13:50:23
is Radiomaster able for SRXL2 ? I don't really know but I don't think so, I have never heard about this possibility - Maybe an other user can help here to clear it up -
PostPosted: Sat 09. Nov 2024 14:48:26
I have edge tx.
I don't think you can use integration.
For use integration you need to install open tx.
But honestly once the helicopter is set up the helicopter flies really well and you never use integration.
On my other radio jeti I have the integration but I never use it.
on my tx16s mk2 max with edge tx I could use the integration if i instal open tx but sincerely I don't need it.
I have a servo plug and it's the best solution why with software pc you can also download logs etc.
decide the best solution for you
PostPosted: Mon 11. Nov 2024 3:51:47
Good evening,
I have a Radiomaster Boxer 4IN1 - Multiprotocol, set with DSM X2F 11ms protocol and it communicates very well with all SRXL2 rx.
PostPosted: Mon 11. Nov 2024 4:09:28
franz88 wrote:
I have edge tx.
Good evening,
The need for radio integration arises to:
1) increase the helicopter's performance
2) not go back and forth with the helicopter (runway -> Box -> runway), attach and detach plugs and etc.
I tried to reserve some radio channels to control in real time the parameters that Spirit2 allows to modify (a great idea compared to integration) but I have commands available such as:
1) Used: 4 AETR commands + 4 switches (Kill Motor, N/Id1/Id2, Rescue)
2) Not used: S1 and S2 proportional
3 free switches that allow me to set only two/three parameters at a time.
I tried, without success, to use the trims to set some parameters but the trims are not linear and therefore do not allow me to make meticulous adjustments
Greetings
Users browsing this forum: No registered users and 9 guests
