It is currently Thu 21. Nov 2024 19:13:50
 Post subject: setup Wizard question
PostPosted: Thu 31. Oct 2024 23:07:27
Hallo All,
Do the 6 degrees have to be positive? in my setup Wizard I have -6 degrees is it right?thanks everyone for your help
PostPosted: Fri 01. Nov 2024 1:49:32
Which blade are you using to take the angle measurement?
Are the blades aligned with the boom?
AFAIK you should always take measurements with the blade over the nose of the canopy.
PostPosted: Fri 01. Nov 2024 7:43:00
it does not matter if you take the blade over the boom or over the nose. and depending on the pitch gauge you are using and how it was zeroed and which blade you are using, there could be + or - 6°.
cheers
Michael
PostPosted: Fri 01. Nov 2024 12:38:18
Tank for your help...i can go fly:)
PostPosted: Fri 01. Nov 2024 13:17:51
don't get confused
It doesn't mean 6 degrees of cyclic
6 degrees in the geometry
and in cyclic ring supported degrees from your mechanics helicopter (about 10 degrees)
