It is currently Thu 21. Nov 2024 19:04:46
PostPosted: Mon 28. Oct 2024 9:37:12
I'm using the Spirit GT in combination with a Radiomaster rp3-h. When powering up the helicopter, half of the times my sticks and switches do nothing. After powering up i get all the right beeps. Swash is moving up en down and then nothing works. I have to unplug the lipo to try again. It's totaly random if it works or not. Sometimes is have to unplug and replug 4 times in a row. Very frustrating. I have tryed unplugging and repluging the rp4-h with the spirit gt already powered up and that way it always works well. TX is a Ranger micro in a tx16s. Tx, rx and spirit unit are all up to date with the firmware.
Can you please help me out?
Friso
PostPosted: Wed 30. Oct 2024 15:22:19
could you please share your wiring?
We have identical setup here with no issues, so we can check also settings. Do you use a bufferpack?
PostPosted: Thu 31. Oct 2024 3:30:51
https://manual.spirit-system.com/index. ... sFire_CRSF
CRSF has seperate rx/tx pins, so for your telemetry problems it sounds like one of the two is not connected right. Not sure if this also causes your other issue.
P. S. @ZeXx86 the wiring page of the manual is missing the CRSF receiver example, I could only find it on this seperate page.
PostPosted: Mon 11. Nov 2024 9:39:11
I do not use a buffer pack. On the rp3-h i have the output marked tx connected to the Rud S. Rx is connected to Ele/pit/ail S.
The + and - output is connected to the Rud + and -.
PostPosted: Thu 21. Nov 2024 16:04:57
Up
