It is currently Mon 07. Apr 2025 15:16:30
 Post subject: update spirit software
PostPosted: Sun 27. Oct 2024 23:48:27
I updated my spirit gt to the version spirit-3.6.5r3-win. (why in this page versione 3.6.5 it is not found? https://www.spirit-system.com/phpBB3/viewforum.php?f=19)
Now I have seen that more versions have come out.
What should I do?
install 3.7.0 and after 3.7.1
or directly latest version?
PostPosted: Sun 27. Oct 2024 23:54:54
As I best understand it, I believe you update directly to the latest firmware version WITHOUT having to conduct incremental updates.
PostPosted: Mon 28. Oct 2024 12:49:34
it does not work
server offline
PostPosted: Mon 28. Oct 2024 17:57:02
Did you try again later?
Flying: OMPHOBBY M2 EVO, Futaba S-FHSS receiver.
Building: SAB RAW 500, YGE Saphir 125 v1, Scorpion HK5 4020-850KV, MKS HV9767 cyclic, MKS 9780 tail, Spirit GT, Spirit Geolink v2, Frsky R-XSR with UNI firmware.
Radio: Radiomaster TX16S II Max.
PostPosted: Mon 28. Oct 2024 18:42:23
it works now.
If i use governor spirit gt and i have hobbywing HV 130A V4 to decrease spoolup (tail kick) what do i need to change?
I have to change the parameters in the software spirit or in the program card esc?
in the past I modified GOVERNOR - FINE TUNING spoolup rate but the start it's always the same
The start is always the same , and after based on the spoolup rate takes turns differently.
I want to change the start of the tail why I don't want to the tail kick
PostPosted: Wed 30. Oct 2024 11:00:25
You will need to modify very likely ESC settings. Spirit has very limited possibilities to limit tail kick. The ESC is responsible for smooth spoolup. So you have to set Spoolup Power in the ESC - described in the HobbyWing manual.
It also depends on ESC mode that is set. Each ESC is different in this area. Very often spoolup is worse when using external governor, because ESC is turning off soft spoolup. But with HobbyWing it should be possible to at least minimize it even with external Governor.
PostPosted: Wed 30. Oct 2024 17:30:16
I contacted hobbywing and he answered me:
""Hi dear sir,
Please see the discription about "Helicopter (Linear Throttle)" mode, the soft start controlled by ESC can only in the first 3.5s, in case that governor external like ****, will provide 10% throttle at the beginning, which could cause a tail kick. But the governor external can take over the soft start in the first 3.5s, when the throttle curve of governor is more gently than the throttle curve of ESC.
However, after 3.5s the spool up can only be controlled by your governor external, and the ESC will respond to the governor external immediately.
So probably, you should adjust the curves and parameters of your governor external.""
only helicopter linear throttle is good (fixed wing has spoolup much faster)
for 3.5 seconds esc hobbywing command spoolup initial
but if I create a curve 0/10/60/60/60/60/60, 10 it is a lower value of 50 and the governor spirit it activates over 50.
I want to understand let's forget about the esc command for this moment, if I use a value less than 50 (10) only to start helicopter, the parameter "spoolup rate" , spoolup rampup They are active or are active only with values ​​above 50% of throttle curve?
I can create throttle curves with as many points as I want (tx16s) if I use low values (0/10/60/60/60/60/60) in theory should start slowly (after in the air i use flat curve 60/60/60/60/60)
but I can also program governor spirit to have a soft start sweeter than the esc in this case the governor spirit commands the start initial
PostPosted: Wed 30. Oct 2024 19:30:13
now listen other question.
I'm trying to make helicopter identical to the simulator I have to speed up the cyclical and the tail.
I speed up the response of the servants or do I increase the degrees for second?
in the simulator degrees for second aileron and elevator is 260 rudder is 560
i use preset goblin 500/550/570/580
value 8 cyclic and rudder piroutte consistancy 160
PostPosted: Thu 31. Oct 2024 1:50:50
As I best understand it, the soft spool-up "tail kick" is a known issue with certain HobbyWing ESCs.
Users browsing this forum: ExCCHP and 4 guests
