It is currently Mon 21. Apr 2025 23:29:28
PostPosted: Thu 26. Sep 2024 12:01:30
I want to use the Spirit GTR. Is it possible tu use CH0-pin of the GTR for a power-backup (IISI Safety Caps 3x50F (Buffer))?
Thank you for your support
Greetings Manni
PostPosted: Thu 26. Sep 2024 12:11:16
yes, this port is perfect for this purpose.
PostPosted: Thu 26. Sep 2024 22:07:31
Yes. The CH0 port is excellent for a capacitor buffer. In fact, all the ports in the rail will work for this purpose except for the ports on either end (SYS and EXT/RPME2).
PostPosted: Fri 27. Sep 2024 6:39:24
... and you can switch it off via TX when on CH0 - as i am doing it with those caps on all of my helis.
cheers
Michael
PostPosted: Fri 27. Sep 2024 20:14:29
aaaand it would be great to have logic out for that channel. Many buffer packs don't have a signal input. I just used a simple transistor to emulate the button press. PWM out on CH0 cannot be used then....
So pleaaase, "a simple logic out" option.
THX!
