It is currently Sat 26. Apr 2025 23:45:05
[ 5 posts ] |
kaidok
Posted: Sun 25. Aug 2024 21:12:19 |
If i plug my battery in on the bench/ picnic table and the spirit GT initializes and then i carry it to my take off spot the heli acts weird and spins on take off. If i initialize it at the take off spot(on the ground), it does fine. What and how can i fix this?
ExCCHP
Posted: Mon 26. Aug 2024 13:42:51 |
Joined: Wed 12. Jan 2022 17:00:01 Posts: 79 Location: British Columbia, Canada
This is more than likely happening because the heli is trying to point itself back to the the original direction when it was inialized.
Myself after the battery is plugged in at the pits and carried out to the filed, I adjust the rudder so the tail blades are at near zero pitch or just a little left yaw. This should eliminate the need for the heli to change directions on spool up.
kaidok
Posted: Mon 26. Aug 2024 17:49:46 |
Perfect!, thank you i will try this.
kaidok
Posted: Sun 08. Sep 2024 3:09:21 |
This seemed to do it, thanks for the help. Please mark as SOLVED.
ExCCHP
Posted: Sun 08. Sep 2024 9:50:13 |
Glad it worked and solved your problem.
Thank you for posting that it worked which, I am sure, is a great help to others with the same problem.
[ 5 posts ] |
Users browsing this forum: Bing [Bot] and 12 guests |
