It is currently Wed 30. Apr 2025 12:30:56
PostPosted: Mon 26. Aug 2024 19:32:12
If I connect an external Hobbywing RPM sensor to the Spirit GT as described in the Wiki, will the RPM coming from the sensor also be displayed in the Spirit's telemetry?
I currently have the Heli-Jive 120 connected to the Spirit's telemetry port, but it is displaying a completely incorrect head speed.
kind regards, Norb
PostPosted: Fri 30. Aug 2024 14:58:33
Yes, when you will connect HobbyWing RPM sensor it will display you this value in the telemetry.
PostPosted: Sun 01. Sep 2024 0:22:51
Unfamiliar with your setup and don't know which Tx your using. But with Spektrum Tx, the setting within the Tx have to remain at default or you will have incorrect rpm results.
The setting are made within the Spirit alone.
Users browsing this forum: No registered users and 18 guests
