It is currently Tue 22. Apr 2025 13:54:57
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Calibration failure
PostPosted: Wed 12. Jun 2024 7:37:15
I am sure we can make it work also with your original units. That is the case for all products we are producing. Even if they are damaged, we can repair all in 99% cases for few USD or for free if it is under warranty. If behavior will be different with new Spirit it mean that your unit has partial damage. Probably in internal LDO (voltage stabilization circuit). This is probably the only technical possibility where Spirit unit could be damaged - at the same time it will not affect flight, because it is used only for side JST ports.
PostPosted: Fri 14. Jun 2024 21:34:30
Ok, I received the new Gt FLB
Updated it to the latest version
Geolink found 14 satellites
Selected the Calibration Tab
Unplugged the units then powered back up
No extra wires going to the FLB just power
When I powered back up, I only got a solid Blue light which flashed a couple of times
As I was going thru the calibration motions
Checked the event logs and it say calibration is done
I checked the heading and for some reason that is about 100 degrees off
So what’s going on with that
John
PostPosted: Sat 15. Jun 2024 18:55:39
Please read above post first
I just talked to Scott Griffis, which has seven heli’s
All with the your GTRS systems on them
He installed another new system last night and he told me that
After he calibrated his Geolink that his compass
Heading is also off, by over a100 degrees
John
PostPosted: Sat 15. Jun 2024 22:38:23
Raceboy1
Instead of chasing Tomas at 18.55 on a Saturday evening, He deserves time off.....
Just read the manual..... https://manual.spirit-system.com/index. ... figuration
Section 2.1......
PostPosted: Sun 16. Jun 2024 7:21:09
raceboy1 wrote:
I just spent three hours with Scott Griffis which has nine helicopters and all of those have your systems in them
He was also unable to do the compass calibration
I came home and tried to do it again in my garage ( with the lights off)
I spent about 5 minutes and never seen one single blink
The only thing I get is the solid Green light that never blinks
Your a Software developer, why can’t you take over my computer and figure out what’s going on
John
how did you do the calibration in your garage?
you have to do the calibration outdoors.
Now I'll tell you something.
I was doing the calibration outdoors and even if I had the satellites the calibration did not come out.
I simply had to change seats and the calibration went well.
try going to a field open without obstacles houses, walls, pylons.
Sometimes even moving 10 meters is enough but in the garage calibration cannot be done (even a wall can interfere).
push calibration button and after at the next startup put the helicopter nose pointing north (you have to see north with a normal compass)
and start doing the movements in the video
https://www.youtube.com/watch?v=skH0u2yV6_M&t=14s
I saw 3d experts don't understand anything about helicopters.
sometimes you just need to skip a step to set a helicopter badly, sometimes also wrap a small washer badly assembled ruins the whole helicopter setup.
and insist on the movements first small movement and after wider movement and so on widening the movements more and more
PS
do not use hot glue on the geolink connector
PostPosted: Sun 16. Jun 2024 8:30:10
Event Log "Calibration si finished" does not refer to GeoLink but to Spirit unit. There also sensor calibration is done, but of different kind.
So it has nothing to do with each other.
Finished calibration of the GeoLink is signalized just at the GeoLink module with flashing LED light with constant frequency ON/OFF until battery is plugged off. Only this will tell you that calibration of GeoLink was finished.
GeoLink calibration can be done anywhere, but it is recommended to do outside at your flying field.
But for testing purpose you can do it also in any building.
It could be Off by 100 degrees if:
a) Calibraiton is done in very strange way - very low probability if it was really finished.
b) Measuring heading in a wrong way. Please note that when model is pointing to North it will correspond to 90 +/- 4°.
All GeoLinks are calibrated in our factory in the same way as you do (manually) to check if it is working properly. If compass heading is off just by 4° then it will not pass the test and GeoLink can't be sold. So you do not have to worry some GeoLink can't be calibrated well. All are working in the same way.
PostPosted: Sun 16. Jun 2024 19:31:09
sorry can you make a video where you show a compass which direction the north points and after show how you do geolink calibration?
maybe in the video at the beginning and at the end show the geolink flashes.
PS
my geolink if I point north I have 90 degrees precisely
PostPosted: Mon 17. Jun 2024 0:14:37
I replaced the GT FLB with another new one that
I purchased from Heli Direct
Now everything is calibrated and working as it should
There is a problem with the first unit I installed
I just finished test flying and checking the different options
And everything performed as it should
Thanks for all of your help
PostPosted: Mon 17. Jun 2024 13:00:37
Thank you for your message.
So it look like the original Spirit unit is damaged.
I dont know how this happened, but could be for example telemetry cable. Unfortunately the unit might require inspection and repair.
If you can send it to us we will find what happened
https://spirit-system.com/repair.php
Users browsing this forum: lubemupski and 14 guests
