It is currently Mon 12. May 2025 14:58:52
PostPosted: Fri 14. Jun 2024 18:02:10
I've been working with Spirit V3.6.1 without problems.
With the new V3.7.0 the Spirit Settings Program doesn't start. If I start the program in a terminal, the terminal disappears and that's it.
For test reasons I downloaded V3.6.2, and this version also works without problems.
At around V3.6.0 I guess there has been a similar problem and the solution at that time was an adapted setting.sh file from Spirit.
Kind regards
toni
PostPosted: Fri 14. Jun 2024 19:39:01
Thank you for the report.
We will test with the same distribution and make sure it will work there. Very likely on monday we will resolve it.
PostPosted: Fri 14. Jun 2024 20:12:46
As temporary workaround please try do delete qt.conf file from the Spirit Settings directory.
PostPosted: Fri 14. Jun 2024 21:12:31
After deleting qt.conf and starting the program, the Spirit Settings display appears but the left bar is completely empty (no symbols) and there are no background-frames in the right area.
If I press any of the above riders (General, Diagnose, Servos, ..) then the Settings Display disappears again.
Kind regards
toni
