It is currently Sun 20. Apr 2025 12:29:53
PostPosted: Sun 09. Jun 2024 8:39:13
I am using HOBBYWING platinum hv160A v4, which comes with an rpm plug. After wiring it correctly, turning on the constant speed and setting the correct gear ratio, the test found that the rmp jumps up and down in a large range (7xxx, 8xxx and then jumps to 0). I tried to change the gear ratio and magnetic pole. , but its current rpm is always higher than the target value. This is obviously incorrect, what should I do?
PostPosted: Sun 09. Jun 2024 8:42:35
is the yellow RPM wire connected at the PIT pin?
This is in the middle of the port.
PostPosted: Sun 09. Jun 2024 8:59:17
Yes just plug in the rpm plug individually to the middle position. No telemetry callback connected
PostPosted: Sun 09. Jun 2024 9:02:52
yes only it to pit pin
Users browsing this forum: No registered users and 66 guests
