It is currently Sun 06. Oct 2024 10:26:56
Posted: Thu 06. Jun 2024 14:43:07 |
Joined: Wed 21. Dec 2016 15:13:38 Posts: 552 Location: Germany
Hello, that's fantastic news ! LUA is now open source I saw that in the Spirit Settings-Tool at News ! I also have to say they made a really great work on the new 3.7.0 Firmware, with much additional possibilities -
I know why I remain loyal to Spirit, it is the excellent customer service that is second to none, thank you very much!
Regards Matthias
senaka
Posted: Thu 06. Jun 2024 16:20:28 |
Joined: Wed 10. May 2023 9:36:53 Posts: 36 Location: The Netherlands
azaz44
Posted: Fri 07. Jun 2024 22:02:27 |
This sounds so great, going to download new version right away, thanks a lot
azaz44
Posted: Fri 07. Jun 2024 22:25:25 |
Not only it works, but it has "log viewer" section there. It doesn't work for me, but it's probably sth coming in future which is great. I actually wrote a simple log viewer for myself in the meantime, this will not be needed anymore.
One has to be careful at the moment, as if you don't close the script by the right button, it leaves Spirit LED blinking. But it's great to see some development made for us.
Posted: Fri 07. Jun 2024 22:36:09 |
Hello, with my configuration doesn't work with the new firmware 3.7.0r2, like with Firmware 3.6.2 !
Telemetry hang from YGE Aureus 135 a short time after start and no stick reactions as by firmware 3.6.2 -
Back to 3.6.1 and all works fine including Integration (Script 3.5.0 r2)-
My config: ETHOS 1.5.7 or ETHOS 1.5.9 the script (3.7.0) does not work with 1.5.7 and firmware 3.6.1 - with 1.5.9 also not because of the other problems (with firmware 3.7.0r2) (sensor lost after short time and no stick reactions)...
Spirit GT Transmitter HORUS X10S Express with ACCESS and FBUS-Protocol Receiver Archer R8 Pro with Archer RS (Signalredundancy)
I think there must some be done...
Edited: added information Spirit GT, I had it forgotten to give this info...
Posted: Sat 08. Jun 2024 7:05:30 |
thank you for your report. We will get same YGE on monday and try to fix it as soon as possible.
Posted: Sat 08. Jun 2024 8:46:23 |
Hello Tomas, thanks for your help !
Short Info to the ESC: This is the first Aureus 135 with peak current 190A - not the V2 (with 230 A peak current) !
Regards Matthias
Attachments: |
leatherface
Posted: Sun 09. Jun 2024 2:24:51 |
Joined: Wed 08. Oct 2014 11:21:06 Posts: 72 Location: sydney,australia
Im still on an older ethos(1.4.15). upgraded to 3.7 firmware and upgraded to latest lua script and mine doesnt work. Most values in lua are wrong or not available. Is this because i need to be on the latest ethos firmware?
leatherface
Posted: Sun 09. Jun 2024 3:05:48 |
So i updated to the newest ethos firmware and my integration is working as expected. logging still doesnt seem to work however.
azaz44
Posted: Fri 14. Jun 2024 8:13:58 |
What also doesn't work is swash plate leveling. If you change any servo subtrim, Spirit switches to swash leveling mode, but comes back to normal mode after half a second instead of staying there.
I think it would be better if it just had a checkbox like a PC app "Subtrim (tuning)". This would be useful, because I find that I very often need to enter this mode without actually changing any subtrims (for example when setting blade tracking).
Users browsing this forum: No registered users and 5 guests |
