It is currently Sat 21. Sep 2024 6:32:01
[ 5 posts ] |
buttles
Posted: Sun 19. May 2024 18:31:59 |
Hi, playing around with Rescue (Normal) today. Tried the Rescue Duration to see how it performed. Then tried to un-tick it but it stays checked. Hopefully something simple to fix but am stumped!! A basic search didn't come up with anything. Thanks
Posted: Mon 20. May 2024 11:17:49 |
Joined: Wed 21. Dec 2016 15:13:38 Posts: 546 Location: Germany
Hello, have you really saved the un-ticked configuration or only changed but not safed ? Sometimes you just forget that in a hurry - Another thing have you banks activatet then un-tick them in all banks -
buttles
Posted: Mon 20. May 2024 12:48:44 |
The autosave function is active but I also backed that up with a manual save. Alas, the same. Been through all 3 banks and it also doesn't clear the tick. Tomas will have to confirm how that particular function is handled I think
Posted: Mon 20. May 2024 13:24:27 |
Hello, one thing will work, I have it no tried but it should - Disable all settings (function) in all three banks so that you have no stabi - save this settings in your FBL - then power up new the FBL, then there must be stabifunction disabled in all banks - Then set all banks again as you want and safe it in your FBL - start the FBL new (new power up) an look if all setting are like you wanted -
If that doesn't work then there must be something wrong and then Tomas has to look what kind of problem that can be -
Hint: I personally dislike autosave and save all manually but that's only my humble opinion -
buttles
Posted: Tue 21. May 2024 7:43:34 |
Thanks for your suggestions. It's not my Heli so can't access it at the moment. We did disable the Stabi functions, save then re-enable Stab normal. This is using the latest software in an old Red unit.
[ 5 posts ] |
Users browsing this forum: No registered users and 42 guests |
