It is currently Fri 22. Nov 2024 0:41:24
 Post subject: use of wifi link
PostPosted: Sun 19. May 2024 15:39:45
Hello, my 2nd day with spirit gt.
I purchased the wifi link, tried that right away, it did not look like the usb windows configurator, could not quickly find gain settings, so went back to hard-wired.
Question: are all features available from wifi, do I need to update firmware for wifi, what features are not available from wifi.
thx for saving me time hunting.
 Post subject: Re: use of wifi link
PostPosted: Mon 20. May 2024 11:09:33
I can't shake the feeling that others should do the work for you?! Just sit down and work with the software like anyone else would/should do - why shouldn't you be able to set everything there? The fact that the interface looks different is ok, that's the case - but actually setting the gains, although you don't even say which ones, should work without any problems - If you don't want to deal with the whole subject of FBL, then it's best to use systems with which you don't have to set anything up - which unfortunately don't exist, except perhaps ready-made drones from well-known manufacturers...
PostPosted: Mon 20. May 2024 16:15:18
well, I see there is no help here from Spirit, unless all these haters can somehow be removed from the forums.
PostPosted: Mon 20. May 2024 17:02:41
You are a really nice person, the only one which should be removed from the forum are you !
Just don't invest your own effort and let yourself be brushed - I'm always happy to help, but people like you won't get any other answer from me - with zero effort from you and excessive expectations, you won't find anyone who will help you - that's it putting yourself on the sidelines, unbelievable!
PostPosted: Mon 20. May 2024 18:47:43
https://manual.spirit-system.com/index.php?title=Wifi-Link
Everything can be set via the wifi link in the same way as via the integration of e.g. Jeti/Spektrum/ETHOS or using the Spirit software.
The latest version for SW, FW and wifi link can be downloaded here and yes, I also recommend updating your wifi link according to the manual.
https://spirit-system.com/download.php
Users browsing this forum: No registered users and 29 guests
