It is currently Fri 09. May 2025 15:58:07
PostPosted: Mon 06. May 2024 20:05:21
today I wanted to change my firmware from 3.6.1 to 3.6.2 of the Spirit GT - Now I have a problem after upgrading to 3.6.2 -
My config:
Spirit GT, FrSky Horus X10S Express and Ethos 1.4.17, protocol (ACCESS) FBUS, Archer R8 Pro and Archer RS ​​(signal redundancy over SBus in/out), YGE Aureus 135A.
After upgrading the Spirit GT I get Sensor lost message and then no telemetry is available -all stick movements have no reaction to the heli - the usb interface is then no more available and will not be found with spirit software 3.6.3 - It is only possible again if the transmitter is off, then the bank will be switched automatically to Bank0 ! If I downgrade the firmware back to 3.6.1 again everything works fine without any problems. Has anyone ever had this? What could be the reason for this?
Spirit software is the version 3.6.3 -
Any help appreciated -
PostPosted: Tue 07. May 2024 8:12:11
is this posted by "you too" or is there at least one similar case described here on helifreak: https://www.helifreak.com/showthread.php?t=948559
(both showing similar results / freeze on combo FrSky/YGE/newest Spirit firmware - no idea if the details are the same, but looks similar at first look)
cheers
Michael
PostPosted: Tue 07. May 2024 10:00:34
Hello HeliMLM,
thanks a lot for your hint !
No, that's not me - on helifreak I am "Heli_Mattes" -
I haven't read the thread yet and only skimmed it very superficially - it's strange that this can occur after a firmware update, but that's just how it happens - the main thing is that there is a solution and then I'll be happy again -
PostPosted: Tue 07. May 2024 15:02:12
we found the same problem and can replicate it with GT/GTR units and some receiver configurations.
We already fixed it in the upcoming 3.7 firmware. It will be released within following days.
PostPosted: Tue 07. May 2024 17:42:28
Hello Tomas,
that sounds perfect !
Thank's a lot for your great work and your very best service -
I am very happy that I have found the best FBL System with Spirit Systems :-) !
Best regards
Matthias
